need help! can anyone recommend a contractor in milwaukee to deal with steam boiler
swerks
swerks Member Posts: 1
the closest search turns up in Chicago. looking for knowledgeable and reliable in Milwaukee
    Steamhead Member Posts: 18,475
    Maybe you could sweet-talk @The Steam Whisperer to ride up there?
    What problem are you having?
    Consulting
    hot_rod Member Posts: 27,426
    There is district steam in Milwaukees, so the larger commercial shops have steam pros, Aherns for example, call them to see if the do or know a residential guy
    Auer Steel is the big Hydronics supplier around there, try them for a lead or look at the message  board at their locations
    Hot Water products reps steam boilers, mostly brewery stuff, maybe they have a lead Jack Daniel’s runs HWP
    kcopp
