Warm Board is making me an offer I can't refuse?
HydroNiCK
Member Posts: 186
I'm looking to get about 300sqft of warm board. Im looking at their website and wondering if it's just me or do they come off as really intense to the point that it's deterring me from ordering. I can't buy from anywhere else other than them. I have to send them plans. They imply the homeowner needs an architect and once they get one Warmboard wants to stop by their office. They want your builders bid and info.. It's like They keep telling me how things are going to be. and they're going to be my new partner and I'm going to like it. And they are letting me know what's best and how things are going to go down. It's wierd. I felt like I was just extorted by reading their website.
The alternate is to use Climate Panels or QuickTrak if you're only covering 300SF.0
We used Warmboard on a few high end jobs many years ago. They were a little easier to deal with then, but certainly wanted to be a little more involved than I preferred. Their product was certainly well made back then and performed as promised. We have not used them in years due to cost, delivery issues, and their need to be overly involved.1
It is just plywood with some aluminum glued to it and a channel cut into it isn't it? Lol
Is that a horse head in your picture 😳EdTheHeaterMan said:It is just plywood with some aluminum glued to it and a channel cut into it isn't it? Lol
Yo, Fredo! Take @JakeCK out back and teach him a lesson.3 -
O.oEdTheHeaterMan said:It is just plywood with some aluminum glued to it and a channel cut into it isn't it? Lol
Yo, Fredo! Take @JakeCK out back and teach him a lesson.0 -
Warmboard is the most expensive option out there. It's most likely going to cost more than the finish floor above it. It was twice the price as the next brand. And the last one I priced during the first year of Covid, had a 3-4 month "you'll get it when you get it" lead time. So I went with someone else.
Do they offer anything special over the competition?0
Have any of you tried Ecowarm...how is it?Paul Pollets said:The alternate is to use Climate Panels or QuickTrak if you're only covering 300SF.0 -
Have any of you tried Ecowarm...how is it?We used it on a job in Berkeley and I’d use it again. Nowhere near as thick of an aluminum layer, but it gets the job done and a lot less $$.
You probably have to use higher water temperatures than with WB, but you'll still be in condensing mode.Comes from Oregon and they usually have plenty in stock.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
First used Warmboard back in the early 00's when it was a new product .. it's gone into a few of my personal projects since. In each case the builder I was working with had never used it so the help from Warmboard was appreciated. The local rep stops over on each project to give a look and advice. Back in the early days they gave you the panel count and layout showing where you had to field route etc. Over time they have added to what they can do for you and what they can supply .... initially they just sold the panels, now they not only sell the pex and manifolds they have an integrated boiler that arrives all set up w/ controls -- plug and play. My last project used about 30k of the the panels and the HVAC guys on the project had used it once years ago. I just needed the panel layout -- there are various ways to set it up and you need the help ...... they don't charge much for that service. You get the set of planes and manifold locations .... each pex loop length. I had them send me the pex-al-pex and the install kit as well. We used Cross manifolds. They have a supply of the product on the east coast in PA so shipping was easy. Found them nice to work with and it's a great product - does it ever make for a solid floor. I like wide plank floors and I know the Warmboard will work .... some of the runs on my last project are 14" wide
1
- 167 Indoor-Air Quality
