Burnham SM 3-2 Ser# 64534188-need fan assembly 6110303
Jagg501
Jagg501 Member Posts: 1
edited July 2022 in Gas Heating
Good morning, I have a Burnham SM3-2 that is in need of a fan assembly only. the motor seized and was able to lube to get it going, but I was told its a matter of time. The part is no longer available and I'm told there is not a replacement. Does anyone know if there is a compatible part in a newer unit or if there is a place I can find the part (6110303)?
  • GGross
    GGross Member Posts: 1,889
    maybe you would have better luck changing just the motor from the fan assembly? Just checked with the master distributor that usually stocks this stuff and they said obsolete with no replacement.
    EBEBRATT-Ed Member Posts: 20,165
    Isn't that nice of Burnham
