Curiosity old piece
Steve_210
Steve_210 Member Posts: 664
I was asked a question and I didn’t know the answer I just wondered if anybody could identify this just curious really
    mattmia2 Member Posts: 15,647
    We need more context. It could be a well tank or cistern, it could be a water heater where the coil was in the boiler and it heated the tank through gravity, it could be an expansion tank.
    EBEBRATT-Ed Member Posts: 19,621
    I was thinking expansion tank.
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,686
    Where is it within the building?
    Retired and loving it.
  • Steve_210
    It was just sitting in an old basement
    It looks like it has 2 try cocks so something where measuring a liquid level is needed like a well tank seems likely.
    hot_rod Member Posts: 26,638
    Any piping still connected? If it is galvanize pipe it may have been for potable water. If steel pipe more likely a hydronic tank
    109A_5 Member Posts: 3,474
    Is that a Pulley Block or Sheave between the tank and the vertical wood (lower right) ?
