Curiosity old piece
Steve_210
Member Posts: 650
I was asked a question and I didn’t know the answer I just wondered if anybody could identify this just curious really
We need more context. It could be a well tank or cistern, it could be a water heater where the coil was in the boiler and it heated the tank through gravity, it could be an expansion tank.0
I was thinking expansion tank.0
Where is it within the building?Retired and loving it.0
It was just sitting in an old basement0
It looks like it has 2 try cocks so something where measuring a liquid level is needed like a well tank seems likely.0
Any piping still connected? If it is galvanize pipe it may have been for potable water. If steel pipe more likely a hydronic tankBob "hot rod" Rohr
Is that a Pulley Block or Sheave between the tank and the vertical wood (lower right) ?National - U.S. Gas Boiler 45+ Years Old
One Pipe System0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
