Share dehumidifier drain off with boiler condensate pump?
In_New_England
In_New_England Member Posts: 166
Should I route a de-humidifier drain into a boiler condensate pump?
I'm thinking it's not an issue since the de-humidifier condensate is not acidic. If anything, it will dilute the acidity of the boiler condensate. It'll also not increase the load, since the de-humidifier is likely running when the boiler is not.
What have I not considered? Thanks!
  • JUGHNE
    JUGHNE Member Posts: 11,547
    I have run a cond NG furnace and it's AC cond water plus a dehumidifier into a single cond pump.
    IMO, the more water and the more pumping the cleaner the pump sump stays.
    In_New_EnglandEdTheHeaterMan
    EBEBRATT-Ed Member Posts: 20,160
    I agree with @JUGHNE but I would pipe them into the pump separately.
