Share dehumidifier drain off with boiler condensate pump?
In_New_England
Member Posts: 166
Should I route a de-humidifier drain into a boiler condensate pump?
I'm thinking it's not an issue since the de-humidifier condensate is not acidic. If anything, it will dilute the acidity of the boiler condensate. It'll also not increase the load, since the de-humidifier is likely running when the boiler is not.
What have I not considered? Thanks!
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
