Old 1920's PreHeater needs identified
ChucksOldBoiler
Member Posts: 14
This unit was originally a Coal fired Preheater for a much larger boiler.
I don't know if it's a Pierce Giant or a Fierce Giant brand.
For the sake of history, Please, anyone with knowledge, feel free to share it here.
This is a pic of the Main Boiler that has been removed after 75 years of service!!!
Pierce. As in the Pierce, Butler & Pierce Co. of Syracuse, NY.
That looks like a coal-fired stove that heated a hot-water storage tank in the summer, when the main boiler was not in use, hence the name "Tank Heater".
What boiler are you putting in to replace the Royal?All Steamed Up, Inc.
Consulting0 -
I relocated the 6" supply & return lines into the main house & replaced it with a Gas fired Crown Bimini BWC225.
Got 12 years out of it and now reads error code E03 I replaced the ignition electrode & cable then cleaned the heat exchanger. Still has error ode E03. Any ideas?0 -
@ChucksOldBoiler
If I am looking at the correct manual that error code does not give much info, it just says "Burner responding to call for heat" I believe you will need to follow the sequence of operation and determine what exactly is causing the lockout. If you have different info on that error code share it0
- 50 Industry Classes
