Anyone know anything about this old steam boiler?
Ando1983
Member Posts: 3
A new state park opened in my area at what was someone's farm long long ago. On one of the trails, you come upon the ruins of the old farm house and this beauty was hanging out front. First, I am glad I didn't have to drag it out front with its 4" thick cast iron walls. I'm assuming the fuel (coal or wood) was shoved in that hole in the front and it heated the flying saucer looking tank above. Does anyone have any info on something like this?
Found this in an old Boiler Book from early 1900's. I know it is generic, but I can see similarities
It's old that's for sure. They were all pretty much the same. The cast iron base is missing, the boiler would have sat 12" or so higher when on the base.
The wood or coal was shoveled in through the opening in the boiler where the fire door used to be. Then it burned on the grates which were down in the missing base0 -
Thank you! What do you think of the return/supply piping both being on top? that kind of threw me for a loop... pun intended0
Those are both supply connections. The return connection is at the bottom, probably on the side.
Any radiators or pipes left in the house?All Steamed Up, Inc.
Consulting1 -
Steamhead,
How were those sections connected?
A single large push nipple between each?0 -
One or two, usually. Some had three.
This type of boiler was something like 40% efficient on oil or gas, according to one of my Dead Men's Books.All Steamed Up, Inc.
Consulting1 -
the old snowman boiler. i bet you can find the asbestos buried in the ground somewhere0
I bet you can find some still embedded between the sections.0
EBEBRATT-Ed said:It's old that's for sure. They were all pretty much the same. The cast iron base is missing, the boiler would have sat 12" or so higher when on the base. The wood or coal was shoveled in through the opening in the boiler where the fire door used to be. Then it burned on the grates which were down in the missing baseOne way to get familiar something you know nothing about is to ask a really smart person a really stupid question0
- 87.1K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
