Dual DHW tanks
Paul Pollets
Member Posts: 3,672
This took some time to make work. The new Viessman V300 tanks have been redesigned to lower production costs.
I thought you retired.
I like the redundant tempering valves.
I also like V. dual coil indirects. We pipe them in series to get the boiler to condense.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
I did retire…sort of. This is a special project that required some experience in a tight mechanical room0
What is that device between the check valve and the gauge on the return of the hot water circulating piping under the polypropylene piping?
And it looks as though you have spring checks before and after the recirc. pump?
Nice work in such a tight space. Not everyone uses unions at the equipment connections.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Looks like a circuit setter0
- 120 Geothermal
