Nipple tray
Snowmelt
Member Posts: 1,454
I have more then a few 2.5 and 3 inch nipples. How do you guys store them, I can’t find nipple trays that big, do you guys fabricat nipple tray at all
I store them in small buckets. Built a partition inside the bucket depending on need/sizes. I cut a piece of wood and screwed it from the outside of the bucket to hold it in place.Snowmelt said:I have more then a few 2.5 and 3 inch nipples. How do you guys store them, I can’t find nipple trays that big, do you guys fabricat nipple tray at all
I use a lot of these bins at work. Maybe they would work for nipples:
https://www.quantumstorage.com/bins-and-systems/dividable-grid/containers0 -
We use old milk crates, but those are starting to fail....at least the plastic ones.To learn more about this professional, click here to visit their ad in Find A Contractor.0
Same here, stackable and very sturdy. Labeling the end is key, I use brother PT labelsmattmia2 said:I use a lot of these bins at work. Maybe they would work for nipples: https://www.quantumstorage.com/bins-and-systems/dividable-grid/containers
With a little imagination you can fab one up for 2.5 and up . Use some dimensional lumber and 3/8 or 1/2 plywood for the sides and some 18 gauge duct scraping for a handle .i believe steam head had some customs trays made up for him . They end up look like a brief case that open on the top . It surely helps keep the inventory and a lot neater then buckets I feel . Milk crates are great to but can be heavy when loaded w 3 and 4 inch nipples . Peace and good luck clammy
R.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Specializing in steam and hydronic heating0
- 50 Industry Classes
