Flow Sensor
Mike Tierney
Mike Tierney Member Posts: 5
This flow sensor, which is used on a closed loop glycol solar thermal system is reading incorrectly. I believe it is approximately 10 years old. I am looking to replace it and have had no luck in searching for a new one. Does anyone recognize this and is there a source for replacement? I will be draining the large system and will be able to see if just a good cleaning is all that is needed. Thank you for your time.
    109A_5 Member Posts: 3,964
    Are you sure the wires are not chafed or otherwise compromised at that mangled termination?
    To me it looks like a Dwyer Series PFT Paddlewheel Flow Sensor
    PFT-IAN-B111-S Standard brass 1-1/2 ̋ NPTM analog output
    PFT-IDN-B111-S Standard brass 1-1/2 ̋ NPTM pulse output
    https://www.dwyer-inst.com/Product/Flow/FlowTransmitters/Paddlewheel-AdjustableInsertion/SeriesPFT
    https://www.dwyer-inst.com/catalog/
    Page 279
    You would have to figure out which it is analog or pulse. The type of input module at the PLC unit may be a clue. There may be a tag if the sensor is elevated on the all-thread.
    Mike Tierney
    EBEBRATT-Ed Member Posts: 20,160
    Is it a flow switch? like with a paddle and a set of NO or NC contacts or is it a resistor that you can Ohm out. Does not look familiar to me
    Mike Tierney
