Heat cabinet sizing
keith123
Member Posts: 105
I want to say it’s a Trane Heat Cabinet. The measurements don’t match exactly with the PDF I have. Perhaps a competitors brand? The actual convectors inside are identical to Trane
Thanks all for your help
Is there a question?
It sounds like your post says that you already know that it is a Trane Cabinet Heater. Perhaps the outer cover was modified or is from a different year production than that which you have a PDF.
Nice tile job over that radiator. A little dated though.Edward Young Retired
For a 4” concealed cabinet depth my length options on my PDF are 18”, 24”, 36”, and 48”
The cabs I’m sizing are 40”, 32.5” etc…
What’s throwing me is the grill design as well.
It must be from a different year other than my PDF
I can use another manufacturer specs with same numbers
I’m wondering if anyone has any lit with cabs featuring this particular grill design0 -
Could be a thatcher, American Rad? I’m still looking0
This site has quite a few pages for Heat Cabinets and similar units:
https://heatinghelp.com/heating-museum/trane-heat-cabinets/
https://heatinghelp.com/heating-museum/how-to-select-and-install-trane-concealed-heaters/
https://heatinghelp.com/heating-museum/herman-nelson-invisible-radiators/
https://heatinghelp.com/heating-museum/murray-radiators/
etc.
Unless you can find an actual name on your units, I'd just use the closest match you can find.All Steamed Up, Inc.
Consulting1 -
I think (faulty memory perhaps) there are some similar in the EDR book as well.
And yes, the taller "cabinets" were site built with parts by Trane or others (I assume mine are Trane because of one of the convector elements being labeled as such and the outputs from the Trane literature matching the rooms fairly closely).
PS I like the tile!0
- 50 Industry Classes
