Heat cabinet sizing
keith123
keith123 Member Posts: 105
edited May 2022 in Strictly Steam
I want to say it’s a Trane Heat Cabinet. The measurements don’t match exactly with the PDF I have. Perhaps a competitors brand?
The actual convectors inside are identical to Trane
Thanks all for your help
    EdTheHeaterMan Member Posts: 11,991
    edited May 2022
    Is there a question?
    It sounds like your post says that you already know that it is a Trane Cabinet Heater. Perhaps the outer cover was modified or is from a different year production than that which you have a PDF.
    Nice tile job over that radiator. A little dated though.
    keith123
    mattmia2 Member Posts: 16,384
    Weren't the in wall cabinets sometimes site built form specs from trane?
  • keith123
    edited May 2022
    For a 4” concealed cabinet depth my length options on my PDF are 18”, 24”, 36”, and 48”
    The cabs I’m sizing are 40”, 32.5” etc…
    What’s throwing me is the grill design as well.
    It must be from a different year other than my PDF
    I can use another manufacturer specs with same numbers
    I’m wondering if anyone has any lit with cabs featuring this particular grill design
  • keith123
    edited May 2022
    Could be a thatcher, American Rad? I’m still looking
    Steamhead Member Posts: 18,393
    edited May 2022
    Consulting
    keith123
  • ChicagoCooperator
    ChicagoCooperator Member Posts: 363
    edited May 2022
    I think (faulty memory perhaps) there are some similar in the EDR book as well.
    And yes, the taller "cabinets" were site built with parts by Trane or others (I assume mine are Trane because of one of the convector elements being labeled as such and the outputs from the Trane literature matching the rooms fairly closely).
    PS I like the tile!
