What low-r value and thin tile decoupling products do you recommend over radiant pour?
rossn
Member Posts: 130
What low-r value and thin tile decoupling membranes/products do you recommend over hydronic radiant that is within a concrete over pour? The thinner the better, and fully moisture tolerant is desired.
Schluter Ditra - 1/8”0
We had porcelain tile installed about six years ago in our new addition. I installed the radiant tubing in the slab and was concerned the Schluter Ditra would negatively effect the heat output. Honestly, I doubt it reduces the output enough to notice. Radiant performs fantastic. By the way, decoupling was considered cutting edge here in NJ at the time.
R value should be practically nothing given the majority of the Ditra surface area are voids filled with thinset.0
- 87.2K THE MAIN WALL
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 75 Pipe Deterioration
- 6.4K Radiant Heating
- 15.6K Strictly Steam
