Buderus g115/4 low limit
kato248
Member Posts: 2
in Oil Heating
Boiler does not keep low limit, Aquastat and 120v relay (taco sr504) replaced when zone calls boiler runs when nothing calls (water/heat) boiler shutdown
Well thanks for the comma and parenthesis anyway.
You late for a plane or something?
The aquastat and the SR504 were replaced?
What model aquastat?
Is it wired XX dry contacts on the SR504 to TT on the aquastat or using ZR,ZC?
Wired xx dry contacts to thermostat on Aquastat l8148 Honeywell thanks for any help Jim0
