Converting electric heating to gas heating
pnm2
Member Posts: 56
in Gas Heating
Is it possible to convert electric heating to gas heating?
What is the range of what this could cost for a 3 story house in Northern NJ?
you can convert from electric to gas, gas to electric, gas to oil, oil to solar. How much money this will cost depends on a lot of factors, what type of emitters you have, and the condition of those emitters.
You aren't going to find anyone estimating your costs on this forum as it is not allowed to discuss pricing, but if you look at the contractor locator you can possibly find someone in your area to give you an estimate1 -
Thank you. My apologies, I was not aware that discussing pricing was not allowed. I will check out the contractor locator.0
Hi, Just curious, what's motivating you to look into this change?
Yours, Larry0 -
A question no one in Connecticut asks...Larry Weingarten said:Hi, Just curious, what's motivating you to look into this change?
Yours, Larry
Sure, anything is possible, but if your electric heating is from individual baseboard room radiators, then your house essentially has no heating system to convert. In other words, you'll have to add a complete heating system from soup to nuts. If the house somehow already has central A/C, then adding a gas furnace to this shouldn't be too difficult as long as the ducting was well designedpnm2 said:Is it possible to convert electric heating to gas heating?
If the house only has electric baseboard heat and no A/C ducting, that means that either air ducting or hot water piping will need to be added. Retrofitting such a system into a home that never had any is very labor intensive unless the home is older and is being gutted for remodeling anyway. Adding air ducting means that you can also add A/C a lot easier as opposed to a strictly heating hydronic system.
Now, if you have the odd electric boiler with hydronic heating already in place, then replacing the electric boiler with a gas or oil boiler is fairly straight forward.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 162 Indoor-Air Quality
- 71 Pipe Deterioration
- 999 Plumbing
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
