Spring Shutdown Soon
bobbob
Member Posts: 70
Getting ready to shut down my NG boiler for the summer. Pros and Cons as whether to shut off pilot, or leave it on. What do you experts say?
I vote for on.0
On.Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.0
Depends. (Not the adult diaper)
I would forget to turn off the pilot on my home on seventh street in Philadelphia. The gas bill would remind me. The pilot on the 1940's American Standard gravity hot water boiler was probably too big, but it worked and I was an oil heat man at the time and knew little about gas heat. The basement was dry and there was no condensation on the cast iron over the summer. I do remember trying to brush clean between the pins of the CI sections, and realized that they were probably never brushed in the 30 plus years it was in that basement, and they didn't need brushing Gas is clean! Oil was dirty. But that was the 1970s
However, if you have a damp basement, and the pilot is not too big, then you might be better off leaving it on.
Mr.EdEdward Young Retired
What Ed said. The pilot light on my old 140KBTU CI New Yorker boiler was stupidly large and burned about $15 month in summer. It was large enough to keep the large internal tank at 160F with no load on system. I learned to kill the pilot on that thing. Relighting was part of the fall pre season check.Don’t miss that beast.
The new 80KBTU Modcon with indirect hot water tank costs less now while suppling all DHW.0 -
It has a very large pilot flame. Wow! I don't want it costing $15 or more per month. My basement does get pretty dank in the summer. Decisions decisions...0
Let it run a month and see what happens.0
DehumidifierHVACNUT said:bobbob said:It has a very large pilot flame. Wow! I don't want it costing $15 or more per month. My basement does get pretty dank in the summer. Decisions decisions...
^^^Yea, What He Said ^^^
That humidity can't be good for the other things in the basement, Like the floor joists and sub-flooring above. Is there a Washer and dryer down there? Storing anything like important papers that can get moldy?
I gave up my 100 Watt incandescent light bulbs and it hasn't felt right since.(the basement) The boiler has been in a tad short of 60 years and I don't have a crystal ball, but I'd predict it wouldn't be here today if it was turned off for 5-6 months every year... so I'm a pilot on guy .One way to get familiar something you know nothing about is to ask a really smart person a really stupid question0
- 50 Industry Classes
