Copper tube thickness for near boiler
rsilvers
in Oil Heating
I use type m cu. Are you sure you need 1.5" piping?0
1-1/4 type M would be workable,a 25 delta would be an option also to lower the flow rate a bit. Nothing sacred about a 20 delta😗Bob "hot rod" Rohr
I know. 4.6 fps if I do a 20 degree drop.It’s ok, but at the edge. I may end up doing a 25 degree drop but won’t know until it is done and pump settings are being programmed. It’s hard to calculate as it will be outdoor reset.0
The are some engineers that will push 5 fps velocity in hydronic systems. Above 5 you start to get some hissing noise. Like when an outside faucet is running full flow.Bob "hot rod" Rohr
There is certainly no reason to use type K copper; that is heavy wall, normally used for underground service.—
Bburd0 -
- 87.8K THE MAIN WALL
- 132 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
