Dual fuel- Propane and electric
TaskPro
Member Posts: 2
Wanted to get opinion from you guys/gals on dual fuel in NH. Propane system with heat pump above 40 degrees. Would be a split system with a coil in the cabinet. These systems are common in NC and SC but didn't know if people have had good experiences in colder climates.
Pretty vanilla setup, the propane can provide emergency backup, but in terms of economics, propane doesn't compete well vs. a heat pump. A cold climate heat pump can output until the negative teens.
Not sure the exact rates you're facing, but at $4/gallon vs. $.20/kwh, a heat pump is 50% cheaper.
Edit: whoops! Plugged in an oil number. If propane is $3/gallon, you’re 25% cheaper using electricity.1 -
Space-Pak is releasing a 4ton ILAHP. Inverter Low Ambient Heat Pump, air to water.
the spec looks like thie, 120F swt, 17F ambient, 36,903 btu/hr, COP of 1.82. temperature range down to -22F
You can run fan coil at 120F or a bit lower with careful diffuser selection and placement.
Similar to how mini splits keep that discharge up high.
Low temperature radiant is ideal and can use a wider reset range.
A few idronics issue with some ideas.Bob "hot rod" Rohr
Living the hydronic dream2
- 123 Chimneys & Flues
