Wall hung boiler attached to brick chimney
Solid_Fuel_Man
Member Posts: 2,644
I'm doing a bid on replacing a wall hung boiler which is attached to unistrut on a chimney. This chimney is only used as a chase for the polypropylene vent and intake pipe.
I was just going to replace the boiler with one of my choice and reuse yhe 2" venting. But in talking to another contractor they said they looked at the same building and that it can't be accached to the chimney.
Thanks in advance!
Thanks in advance!
We, as a matter of course, just specify a new built wall to mount the boiler. We build the wall with the boiler configured in the shop and transport the entire thing to the job site. Makes it simple. The wall is usually 2x4 framed with some mounting surface either drywall or something else prettier depending on how fancy we want to get. We have yet to find a homeowner nostalgic about their basement walls.1
I was considering using strut floor to ceiling. I actually have a wall hung boiler already....I bought several ECO70 and got a good deal on them before things got crazy expensive.
But I don't have to use it, would just male piping that much simpler.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0 -
- 116 Geothermal
- 15.8K Strictly Steam
