straight, adjustable steam air vents for old steel convector radiators
Don10000
Don10000 Member Posts: 21
Can anyone suggest a good, straight, adjustable steam air vents for old steel convector radiators? The Ventrite #51's I have work great and wanted to get more but Ventrite no longer makes straight adjustable. Can anyone recommend anything similar? Looking to balance the system so needs to be adjustable.
    EdTheHeaterMan Member Posts: 11,995
    edited March 2022
    Have you considered this angle to straight steam vent adaptor?
  • Hap_Hazzard
    Hap_Hazzard Member Posts: 2,919
    I think the Dole 1933 SV is ⅛" straight and adjustable, but I doubt you'll find one of those either. USAV makes a ⅛" straight vent and a ⅛" adjustable vent, but I don't know if they make a ⅛" straight adjustable vent, but they're not very good vents anyway.
    Most of us manage to blance our systems with fixed vents. Maid-o-Mist vents come in ⅛" straight and have interchangeable vent ports. Someone said they even make an adjustable port, but I've never seen one.
    mattmia2 Member Posts: 16,394
    I bet you could make an adjustable vent for a Maid-O-Mist with a needle valve.
    Steamhead Member Posts: 18,393
    Consulting
  • Hap_Hazzard
    Steamhead said:
    That's a ¼" vent. Make sure that's what you want.
    edited March 2022
    C'mon, now this is too funny for a private message.
    I need to add this to the "Nearly Famous Quote"
