calcium in water heater
george_42
Member Posts: 123
Has anyone ever tried removing calcium from tank
water heater using calcisolve or hcl
Used to be a product called a muck vac that could flush out heaters, somewhat
How old is the tank? At some point the accumulation becomes more like concrete, tough to flush out a 3/4” opening.
What is your waters hardness?Bob "hot rod" Rohr
Hi @george_42 , It's fun that @hot_rod mentions the Muck Vac. It's a tool I came up with to solve noise problems in water heaters long ago. Haven't made them for years now. Still, there is a product called Mag-Erad, that is a citric acid based descaler. It can help some. It's non-toxic and won't damage the glass lining. I'd install a curved dip tube and full port ball valve for the drain. Then the tank can be flushed using water pressure. Possibly using both Mag-Erad and flushing together will give the best results. FIY waterheaterrescue is the place to go for flushing parts. So, what's the tank doing that makes you want to clean it?
Yours, Larry0 -
Mag-Erad Water Heater Cleaner is easily found as sku 6831000 in the new 2 pound more economical package with the new United States Patent at Menards. A. O. Smith also is working on the new size upgrades and the sister product for those million BTU type heat exchangers is the A. O. Smith Un-Lime Delimer. Note that the National Codes have been changed. Temperature and Pressure Relief Valves on potable systems must be removed and waterside inspected for clogs and fallen off or corroding probes and the CSA NOT NB/ASME rating used because potable water is 20-80 pounds and the ASME Rating is 150 Pounds, or 360 degree Fahrenheit Water, clearly dangerous. The CSA rating assures the water never exceeds 210', remains under boiling, does not expand double nitroglycerine as water does when it flashes to steam as the pressure drops to under the boiling point of the superheated water. Mag-Erad is at Menards and that is a lot of locations nationally, more coming.-1
- 50 Industry Classes
