Steam radiator leaking steam
hdp203
hdp203 Member Posts: 3
edited March 2022 in Strictly Steam
Hi All,
Please see the attached pictures for the location of the leak.
Is that something fixable or better just to replace the radiator?
I am handy but not an expert in anyway.
Thank you in advance for your advice.
John
  • bburd
    bburd Member Posts: 1,300
    The end section is cracked. That radiator is done.
    Fortunately used radiators are not hard to find. New ones are quite expensive.  You should replace that with the same material (cast iron) and heating capacity, assuming the room heats evenly and well.
    Bburd
  • hdp203
    Thank you.
