boiler repipe
smc
smc Member Posts: 18
  • smc
    Thinking we should fix this. System seems to work fine. Has a couple fan coils with steam traps 1st floor and radiators second floor. Any ideas if will cause problems other than maybe a spot for sludge to collect.
    thanks
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,580
    Is that connection pipe to the wet return under the waterline?—NBC
  • smc
    i think it is
