Thermostat bypass for testing & skimming
Hap_Hazzard
Member Posts: 2,919
I used to just grab a clip lead and jumper out the thermostat wires when I had to skim my boiler, but it was a little hard to keep the water temperature at the boiling point that way, so I decided to put in a bypass switch. As I was rummaging through my switch bin, I found this timer, and decided that might be a better thing to use because I could use it for testing scenarios, and it would also be safer, because I couldn't forget to turn it off if I got distracted.
While I was at it, I moved the transformer from the breaker box to the boiler and added an on/off switch so I can kill the power to the boiler without having to run to the breaker box.
Nice idea. Isn't there a master switch required somewhere near the boiler (red metal cover plate)?
I wired up a second thermostat near the boiler so I didn't have to go from the basement to a second floor front apartment, through 3 locked doors.
I connected each thermostat to terminals on a SPDT (ON-OFF-ON) switch in a junction box and mounted it in the overhead near the boiler.
Some time later, I changed to a Honeywell wireless thermostat (battery powered) with a wifi gateway and now I can monitor and control the thermostat from anywhere I have wifi. No more going up and down stairs. One of the tenants let me connect the gateway to her router.
I'm not sure what the code says, but there was no such switch when I moved in. It did seem like a good idea to add one. If I still have this boiler when I sell the house I'll have to see what the code says and bring everything up to code as much as possible.SteamingatMohawk said:Isn't there a master switch required somewhere near the boiler (red metal cover plate)?
1983(?) Peerless G-561-W-S | 3" drop header, CG400-1090, VXT-240
- 50 Industry Classes
