Need Sunray Bantam Burner "Stabilizer Assembly" For American Burham V-14 Boiler
jbar
Member Posts: 7
in Oil Heating
I have a Old "Burham America" V-14 FC Bantam Series Boiler with the Sunray FC Series Burner. I need a Replacement "Stabilizer Assembly "Part # A 42640, which holds the 2 Electrodes in place. The right side mount cracked. Also i want to purchase 2 Ignition Electrodes Part # E 41451.. I wouldn't mind getting the whole Firing Assembly which is part # A 42641 even if used but The most important part i really need is the Stabilizer Assembly which holds the electrodes in its proper position. Does anyone know where i can purchase one whether it be New or Used ?
FC-134? For real?0
Unfortunately, Sunray went out of production decades ago, which is a shame since their burners were quite good.
Later V-1 series boilers used Beckett AFG burners.
Where are you located?All Steamed Up, Inc.
Consulting0 -
@jbar
You would be better off getting a new burner evan a used Beckett AF there are thousands of them probably could get one at a junkyard and fix it up.0
- 120 Geothermal
