This is just wrong on so many levels.
Hap_Hazzard
Member Posts: 2,919
Would've been better added to the ol meme thread IMO.
Have you ever had a level that wasn't?0
I like to think Starrett machinists levels we have aren't. They are adjustable.SteamingatMohawk said:Have you ever had a level that wasn't?
So, it can be an intentionally unlevel level.0
File this under "dad jokes".All Steamed Up, Inc.
Consulting2 -
No you adjust them so they're correct.SteamingatMohawk said:So, it can be an intentionally unlevel level.
Correct.
But, if you want a consistent pitch on something, you could intentionally unlevel the level, within the range available for the level (which probably isn't much).
I've done that with a piece of wood and a shim taped to it when setting pitches outdoors.0 -
Yeah I suppose you could do thatSteamingatMohawk said:Correct. But, if you want a consistent pitch on something, you could intentionally unlevel the level, within the range available for the level (which probably isn't much). I've done that with a piece of wood and a shim taped to it when setting pitches outdoors.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
It was for backfilling gardens around the house after removing 30+ year old overgrown shrubbery, etc.0
- 117 Geothermal
