This is just wrong on so many levels.
Hap_Hazzard
Hap_Hazzard Member Posts: 2,919
ayetchvackerdelcrossvErin Holohan Haskell
  • ChrisJ
    ChrisJ Member Posts: 17,276
    Would've been better added to the ol meme thread IMO.
  • SteamingatMohawk
    SteamingatMohawk Member Posts: 1,101
    Have you ever had a level that wasn't?
  • ChrisJ
    I like to think Starrett machinists levels we have aren't. They are adjustable.
  • SteamingatMohawk
    So, it can be an intentionally unlevel level.
    Steamhead Member Posts: 18,393
    File this under "dad jokes".
    Consulting
    Hap_HazzardErin Holohan Haskell
  • ChrisJ
    No you adjust them so they're correct.  ;)
  • SteamingatMohawk
    Correct.
    But, if you want a consistent pitch on something, you could intentionally unlevel the level, within the range available for the level (which probably isn't much).
    I've done that with a piece of wood and a shim taped to it when setting pitches outdoors.
  • ChrisJ
    Correct. But, if you want a consistent pitch on something, you could intentionally unlevel the level, within the range available for the level (which probably isn't much). I've done that with a piece of wood and a shim taped to it when setting pitches outdoors.
    Yeah I suppose you could do that
  • SteamingatMohawk
    It was for backfilling gardens around the house after removing 30+ year old overgrown shrubbery, etc.
