Heater shuts off
I know this is off topic but in trying to figure everything else out I went down a wiring path that led me to check the outside and I THINK the Y1 and Y2 are backwards - but not sure. For a 2 stage compressor (cooling) -
1. Should the outside condenser fan change speeds when changing from stage 1 to 2 or does the fan stay the same, just compressor changes?
2. when the ac kicks in stage 1, shouldn’t the outside fan also kick on?
