Steam Pipe Installation
nlongworth2
Member Posts: 13
I'm getting the asbestos insulation removed from my steam pipes in the basement. What type of insulation material do you recommend replacing it with? I've seen options for fiberglass, elastomers (Insul-lock) and other options.
Thanks!
Thanks!
The insulation most commonly recommended here is fiberglass 1" thick. I ordered mine from
https://www.buyinsulationproductstore.com/Fiberglass-Pipe-Insulation-SSL-ASJ/
The pvc covers for elbows and tees look good.
3
- 15.8K Strictly Steam
