If our community has helped you, please consider making a contribution to support this website.  Thanks!
carr's positive circulating radiators - Can I convert to water?
                    nickDC
                    Member Posts: 6
                    All I pulled this out a house we're renovating - the owner was going to trash. I have a hydronic system in my house but I have never seen this radiator before. Can I convert to water? It is beautiful I have one column and two others.
Nick
Nick
4
            If only one pipe connection probably not working with water.
But I am sure someone here would want them....priceless!0 -
            @nickDC
I bet you could find a place on the top header to drill and tap a 1/2" pipe thread. I would do it on the opposite side of the existing tapping at the top1 -
            This type of valve works well on one pipe radiators. I have played around with one on several different radiators in my shop. Adding a small 1/8" auto vent vent up high assures you get the most amount of water into the radiator. They will heat without being 100% filled.
Air space gets you a false expansion tank in the system.
https://www.caleffi.com/sites/default/files/file/01051_en.pdf
The Caleffi is not sold in the US, but I believe Oventrop has them available in the US.Bob "hot rod" Rohr
            hot_rod - thanks that is a great solution. I'm attaching more pics of the opposite side and the other two radiators
. It looks like another place where if I could undo the plug I could put a return valve. The one thing I am wondering - From the pdf of the 1874 tech specs - is that a water seal below thats locks the steam in the upper tubing until it turns back to water. And it would just act like one big chamber even if filled?0 -
            I don't think these will work on hot-water, even with those Oventrop valves. But please salvage them, they are classics!!!!!All Steamed Up, Inc.
Consulting0 -
It would be worth trying one with a conversion valvenickDC said:hot_rod - thanks that is a great solution. I'm attaching more pics of the opposite side and the other two radiators
Do you have a source of hot water? A small electric water heater and a circulator would work
They would need to be able to hold pressure also.
            There was a simple single 3/4" insert double pipe valve that would go into a WH tank drain valve opening for the desuperheater from WTA geo heat pumps.
Long 1/2" od tube to the inside and 1/2" od on the shell of the valve.
Constant flow from the HP until hi temp reached. No adjustments.0 -
            I don’t think those tubes are connected at the top. They probable have an internal baffles to allow steam and air to pass each other. I’ve never seen these converted to water.Retired and loving it.0
            Since the vertical pipes are threaded on both ends I would think one end must be a LH thread???0
            In the 1890 St Louis house posting, there is a picture of a round table top rad with 2 pipes connected and an air vent.
May not be the same at all.0 -
so after the round and round I will need to get rid of these - anyone have a sense of what they are worth?
Are you in Washington DC?
I'm not sure if you're going to get much for them but someone like @Steamhead may be able to rehome them.
 - 87.2K THE MAIN WALL
 - 118 Chimneys & Flues
 - 113 Geothermal
 - 164 Indoor-Air Quality
 - 73 Pipe Deterioration
 - 6.4K Radiant Heating
 - 393 Solar
 - 15.5K Strictly Steam
