Lochinvar NKC 199
fillip137
Member Posts: 1
in Gas Heating
Had this unit for 4 years and nothing but problems right now making heat not hot water when calling for just water it cycles ignition prepurdge and post Purdge little faucet on screen blinks . Replaced flow sensor before this. Had heat not hot water any ideas ?
Lochinvar's are good boilers. If it's not working right it may not have been installed right or was not set up properly.
Find a contractor that knows Lochinvar boilers or call Lochinvar for a recommendation0 -
Agree with Ed. Lochinvar are good products- may not have been installed correctly. I have two that have performed with no breakdowns for over 10 years with hard use.0
Has the heat exchanger ever been cleaned?0
- 15.8K Strictly Steam
