Lochinvar NKC 199
fillip137
fillip137 Member Posts: 1
Had this unit for 4 years and nothing but problems right now making heat not hot water when calling for just water it cycles ignition prepurdge and post Purdge little faucet on screen blinks . Replaced flow sensor before this. Had heat not hot water any ideas ?
    EBEBRATT-Ed Member Posts: 20,165
    Lochinvar's are good boilers. If it's not working right it may not have been installed right or was not set up properly.
    Find a contractor that knows Lochinvar boilers or call Lochinvar for a recommendation
  • BigRob
    BigRob Member Posts: 332
    Agree with Ed. Lochinvar are good products- may not have been installed correctly. I have two that have performed with no breakdowns for over 10 years with hard use.
  • GroundUp
    GroundUp Member Posts: 2,513
    Has the heat exchanger ever been cleaned?
