Navien combi boiler systems
FrankCesca
Member Posts: 1
I currently have a 32 year old peerless boiler Beckett burner oil fired system with an electric water tank and I’m interested in replacing it with a new system. The Navien Combi boiler fired by liquid propane was highly recommended to me as an energy efficient system, however I read some concerning reviews about the true efficiency of the system and its durability and difficulty getting replacement parts. I’m not sure if I should stick with an oil fired system similar to the one I have or venture out and try one of these energy efficient systems. Any help or advice would be greatly appreciated.
@FrankCesca
The debate continues about CI boiler versus Mod Cons. There are some good mod cons but I wouldn't include Navien on the good list
The short version:
MOD CON more $$$
More efficient (in some cases depending on your system)
Shorter life span maybe 15 years
Sometimes you have to wait for parts
parts are $$$ and are perpriotery you have to go to the boiler mfg
Not everyone can work on them
CI boilers
less $$$
Should last longer....your 32 year old boiler is a good example
parts are more generic, it would be rare not to be able to fix up a 30 year old boiler
parts are less $$
The average service tech "should" be able to service it
I will stay out of the oil versus propane debate except
getting rid of the oil tank can be a bonus if your going to sell the house
Oil is 140,000 btus/gallon
Propane is 91,500/gallon
Efficiency wise CI boiler will be in the 82-83% range on either fuel
A mod con (even though they are advertised at 95%) will only do 95% if connected to a low temp radiant system
With baseboard HW they are probably 88% if you have CI radiators they may be around 90%
Whatever you decide the quality of the installer is most important
We see horror stories here every day
Anything but a Navien....getting parts for them isn't a problem actually. Reliability and quality of the boiler itself is. I would stick with oil myself and replace the boiler with an Energy Kinetics or three pass cast iron myself. Quality of the installation is the most important thing with any boiler.1
In the early days of computerization of road racing motorcycles, Eraldo Ferraci, a great builder, pointed to a black box, padded and insulated, stuck under the seat and between 2 upswept exhaust pipes and said: “ No one in there is happy!” He was referring to all of the sensitive electronic parts. I think of that when I look at a mod con. Any mod con. Every time I look at a mod con. Including my own.
Now, I like mod cons. The science is elegant. Takes awhile to dial one in. After you select and pipe it. And a bad installation is real trouble.
I personally would go with a cast iron boiler and efficiency in the low to mid 80% range if I had to use water temperatures that (largely) put a mod con out of condensing range.I don’t like the idea of (still) sensitive electronics and electrical parts subjected to all those heat cycles. As a disclaimer, I am not a pro. Always been a science geek. And took a lot of thermodynamics courses.
Best wishes0
- 50 Industry Classes
