Decorative c. 1920 Cast Iron Hot Water Radiators
davidk2022
Member Posts: 2
I am planning to update the heating system by removing the gas-fired pumped hot water heating system with heat-pumps. This transition will happen in May/June 2022.
All from a 4 story brownstone in Brooklyn, NY.
Available: 18 decorative cast iron radiators of various sizes. See attached list w/sizes. Didn't include pictures of all, but attached should give you the idea of what's what.
All in service today (especially today being so cold!), without leaks.
$2000 for the lot. All will be disconnected and drained. Must be picked-up in Brooklyn.
If you interested, I also have fully functional 25-year old Utica 100,000 BTU gas fired hot water boiler, complete with pump, 1-year old gas valve, controls, etc... Free if you take it with the radiators.
Too far away for me to consider.
Great looking building. The rad fit in so well with that era of decor.
What prompted this upgrade. I assume minisplits...0 -
yes --- dumping fossil fuels and want central air.0
Did you ever consider having both?0
Before you tear these out, you'll need to live with the heat pump for a winter. Given heat pumps' extreme lack of comfort, I bet you won't make it past mid-December without re-starting the boiler.All Steamed Up, Inc.
Consulting1 -
I am in need of 2 or 3 , I will buy them assuming I can arrange shipping contact me hoffmanhomekevin@gmail.com0
Hello davidk2022 i am also in need of some you can contact me at cee710@gmail.com
thank you.0
- 87K THE MAIN WALL
- 58 Biomass
- 116 Chimneys & Flues
- 109 Geothermal
- 994 Plumbing
- 389 Solar
