Decorative c. 1920 Cast Iron Hot Water Radiators
I am planning to update the heating system by removing the gas-fired pumped hot water heating system with heat-pumps. This transition will happen in May/June 2022.
All from a 4 story brownstone in Brooklyn, NY.
Available: 18 decorative cast iron radiators of various sizes. See attached list w/sizes. Didn't include pictures of all, but attached should give you the idea of what's what.
All in service today (especially today being so cold!), without leaks.
$2000 for the lot. All will be disconnected and drained. Must be picked-up in Brooklyn.
If you interested, I also have fully functional 25-year old Utica 100,000 BTU gas fired hot water boiler, complete with pump, 1-year old gas valve, controls, etc... Free if you take it with the radiators.
  • JUGHNE
    JUGHNE Member Posts: 11,527
    Too far away for me to consider.
    Great looking building. The rad fit in so well with that era of decor.
    What prompted this upgrade. I assume minisplits...
  • davidk2022
    davidk2022 Member Posts: 2
    yes --- dumping fossil fuels and want central air.
  • JUGHNE
    Did you ever consider having both?
    Steamhead Member Posts: 18,324
    Before you tear these out, you'll need to live with the heat pump for a winter. Given heat pumps' extreme lack of comfort, I bet you won't make it past mid-December without re-starting the boiler.
    Consulting
    delcrossv
  • kevinhoffman
    kevinhoffman Member Posts: 4
    I am in need of 2 or 3 , I will buy them assuming I can arrange shipping contact me hoffmanhomekevin@gmail.com
  • cee710
    cee710 Member Posts: 1
    Hello davidk2022 i am also in need of some you can contact me at cee710@gmail.com
    thank you.
