Burham v-14a-t leaking from tankless coil
Greetings,
I recently inherited my mother's house which is equipped with a v14a-t boiler that has developed a leak from the decommissioned tankless coil... it's a slow leak that only drips when the boiler reaches max temp/pressure.
My google-fu led me to this sight where I was able to find the parts #'s for the gasket and tapped cover plate... the only problem is the plate is on backorder... and further reading leads me to believe that even if I did have the parts there's a good chance I won't get the bolts out without breaking them.
Other internet research led me to a possible stop gap solution in boiler sealant/weld. Does this seem like a feasible solution to this problem?
I realize this boiler is 30yo but would like to get it through the worst of this winter...
Thanks in advance...
  • Big Ed_4
    Big Ed_4 Member Posts: 3,515
    is the leak dripping out of the old unused pipe taps or. is the leak from the gasket ?
  • It's coming from the top edge of the coil plate. It's dry around the pipes.
