Peerless hot water boiler leaking
ranzerox
ranzerox Member Posts: 55
edited January 2022 in Domestic Hot Water
My hot water boiler is leaking. It appears to leak when its heated. Can these be repaired? Thanks!
MI-05-STDG-WPC
    EBEBRATT-Ed Member Posts: 20,172
    Probably not if it's the boiler itself. You can use boiler stop leak to hopefully get through the winter
    ranzerox
    HVACNUT Member Posts: 7,443
    Where's the leak coming from?
    ranzerox
  • ranzerox
    @HVACNUT, i believe above the burners, not 100% though.
  • ranzerox
    I never considered the flue, I'll keep an eye on that. The only evidence I've come across are water stains on the painted floor. I don't know how much water. The water supply should be on. Thanks
