Crane boiler info
Jones1
Member Posts: 7
Was wondering if anyone could help me with year and where I could find info on this crane boiler
It can't be newer than 1972 or so, since Crane sold their boiler line to Slant/Fin around that time.
It does appear in the Beacon Boiler Reference, here:
https://heatinghelp.com/heating-museum/part-2/All Steamed Up, Inc.
Consulting0 -
Thank you. Is there anywhere I can get a manual or some more info0
Doubtful on the manual but you shouldn't need one . It's a simple gas fired atmospheric boiler0
Ok thank you. Can anyone help. Boiler is releasing water out of pressure relief valve. Had mechanical service replace but still leaking. Pressure gage use to stay between 20 and 22 psi now holding between 12 and 15 psi. Not sure what way to go from here0
You almost certainly have a waterlogged or otherwise faulty expansion tank. This is not part of the boiler itself.—
Bburd0 -
Thank you very much. Where approximately would expansion tank be located0
There are three possibilities depending on the age of the system.
Modern expansion tanks are the bladder type, typically connected to piping near the boiler. Usually gray in color.
Older systems designed for forced (pumped) circulation usually have a compression tank hung in the ceiling over the boiler. These occasionally become waterlogged and must be drained and refilled to restore their function.
Very old systems designed for gravity circulation usually had an open expansion tank in the attic. These are often replaced with one of the above two types when the boiler is changed.—
Bburd0 -
Thank you very much trying to get this narrowed down for my mom. She gas had two different mechanical services telling h er two different things.0
@Jones1 , where is your mom located? We might know someone who can handle this............All Steamed Up, Inc.
Consulting0 -
We are in central illinois0
Not sure exactly where some of these contractors are located, but you might start here:
https://heatinghelp.com/find-a-contractor/state/ILAll Steamed Up, Inc.
Consulting0 -
Thank you much appreciated0
