Hydrostat 3250 settings help
jbhulagirl
Member Posts: 8
My oil company replaced my boiler and added a hydrostat 3250. Currently my thermostat is turned off. Hydrostat set to Econ 1, low 120, high 140. The boiler runs every 15 mins or so bringing the water up to temp (as I think I understand it) my house is 76 degrees. Oh and I’ve blown thru 1/4 tank of oil in a month. Remember my thermostat is turned off. My question is what are the proper settings on the hydrostat to keep it from running the boiler so much and from roasting me out of my house.
My old unit, didn’t have a hydrostat and only kicked off via thermostat and my house was always a comfortable 68 and my oil consumption was much much lower.
My oil company is not very responsive and quite honestly I think they want me to blow through my oil faster.
Please help.
Need more information. Do you get your domestic hot water off the boiler?
How many zones do you have?
Do you have zone valves or circulators?0 -
Only one zone. And I have a separate hot water heater. Not connected to my boiler.0
The oil company that installed said that Econ should be set to 1 and low 120 and high 160. It truly is cooking me out of my house. And like I said, I’m blowing through my oil much faster than I imagined.0
If you don't use your boiler to make domestic hot water, lo should be off, high can be 160°, circulator hold off should be on (enabled). Like @HVACNUT said, if your thermostat isn't calling for heat, the burner shouldn't run.
It's also possible you are getting ghost flow from a failed/missing check valve.There was an error rendering this rich post.
3 -
I feel so at a loss because hvac isnt something I kind diddly about. I only know that my last boiler, if I needed heat I turned up the thermostat. This thing runs every 15 mins for about a minute with the settings I previously mentioned and my house thermostat is off and the current house temp is 71. I appreciate all your comments and I have tried calling the installer but they dismiss me. Very frustrating when I just want it to run as I expect and be more efficient than my 50 year old boiler I replaced. So far that is not fulfilling my expectations.0
This seems odd to me. I wouldn't think the boiler would fire every 15 minutes to maintain temp if the thermostat was not calling for heat. Sounds like you are getting flow through the heating system even though the thermostat is off. You can carefully feel the pipes coming out of the boiler to see if they are hot. If they are there is a problem. For reference I only use ~1/8 a tank per month in the summer to produce hot water.
BTW, what model boiler did they install?1 -
Slantfin boiler model temperature-30-1.10p. All pipes coming out are warm to the touch0
I don’t know what ghost flow really means or how to fix it. But what I have done is set Econ to 1, low to off and high to 160. That was an hour ago and so far it hasn’t kicked back on. Hoping that is the magic setting!! I suppose the oil company had “their” settings so I buy more oil. Fingers crossed you’all have helped solve my settings thank you1
@jbhulagirl
Ghost flow is water moving through the pipes when it shouldn't be. Water should only move when the circulator is running. Probably a bad flow check valve.
Check "find a contractor on this site" or post your location. Your contractor sucks. Someone here may be able to recommendation in your area
Post the city you are in2 -
Don't know if Bel Air is near Baltimore? @Steamhead0
Bel air is close enough to Baltimore.0
- 87K THE MAIN WALL
- 58 Biomass
- 112 Chimneys & Flues
- 106 Geothermal
- 980 Plumbing
- 388 Solar
