I have clicking noise from argo panel
Bridget_007
Member Posts: 1
in Oil Heating
I don't know much except last night argo panel lights were trying to go on and making a buzzing noise, so I shut the system down
…then you called your competent technician…then what?
Buzzing noise could be normal for a change in a transformer or relay or voltage level, but electrical related noises means something is trying to work and has or is failing. Ask for a control tech to figure it out. Anything changed between before and after, let them know. May mean nothing but you never know. Loose wire? or a wire shorting out somewhere. Argo Relay panels can control valves, motors, respond to input from thermostats, limits turn things on and off. Good luck.0
