What is the best solder and flux for hot water heat with plumbing?
eclecticmn
Member Posts: 129
What is the best solder and flux for hot water heat with copper plumbing?
This is not for drinking water.
I am not a professional. I have sweated some copper pipes before. Not well but they did not leak.
Home owner near Minneapolis with cast iron radiators, one non working slant fin now ripped out, and hot water heat.
I like Canfield silver solder, watersafe. I like Oatey #95 flux.0
50:50 tin:lead solder and Oatey flux. I'm a DIY'er and I've soldered up to 1-1/4" copper easily with them.0
Is there a brand for 5050 tin lead solder? I see some for stained glass. Does that matter?Home owner near Minneapolis with cast iron radiators, one non working slant fin now ripped out, and hot water heat.0
The role I have is branded from my local Do It Best hardware store. Brand shouldn't matter as long as it an acceptable diameter.0
Oatey No. 85 is a tinning flux with some solder in it. Green label container.
In a bind on Sunday I bought solder at Lowes, "Select" lead free. It's made by Harris, one of the top brands. I believe the box stores have small sizes of Oatey flux also.Bob "hot rod" Rohr
I like Silvabrite solder (it is $$) and "NoKarode tinning flux)
On heating with a backflow preventer you can use whatever solder you want.
50/50 is easy to work with flows like water.
95/5 I hate, almost impossible to fill a gap or hole with it
I always disliked "utility flux" that's what my shop used to buy.
I would just go buy my own supply of NoKrode
Staybrite #8 solder and Nokorode flux.Steve Minnich0
