Pool water
imccleaf1963
Member Posts: 1
Is a titanium heat exchanger good with salt chlorinator in home swimming pools?
Pentair ultratemp 110 heat pump and Pentair IC30 Salt chlorinator.
Any pros and cons of each.
all pools have salt, including pools treated with "pucks". there is usually a slightly higher ppm in a salt cell pool compared to conventional pools but not enough to sway heater choice. I deal with raypaks and like the cupro nickel models but do nat gas heaters. if you dont plan on using the heatpump throughout the season install a bypass in the pvc piping. also make sure whomever installs it follows the particular instructions for that model, they all have a bypass of sorts in their required piping1
