HB Smith boiler with power flame burner
Phillip Biston
Member Posts: 42
My HB Smith boiler has a power flame burner the shut down and I reset it this morning, it is running but there's clicking noises sounding like coming from the gas shut off valve solenoid and the pilot light valve solenoid. I am wondering what I should be checking?
@Phillip Biston
I agree. Loose wire ids the first thing to check. Is it the pilot solenoid and pilot lig blinking or main flame as well?0 -
Thanks for the advice, will be checking for loose connections.0
I hate to say this but you may have enough knowledge to get in trouble, call a qualified service company to check it out or repair or replace what is defective.
JakeSteam: The Perfect Fluid for Heating and Some of the Problems
by Jacob (Jake) Myron0
- 117 Geothermal
