Steam Supply line vents
AldebaranAf10
Member Posts: 1
Are they necessary
You may not need them if you are still burning coal. This was a continuous fire that would slowly vent air thru the radiators and remain fired for most of the heating season. If your coal fire went down to zero then it would be a long process to remove all the air again thru the small radiator vents.
But if you have a boiler that cycles on and off (oil or gas) then it behooves you to have massive steam main air vents. It will get the air out of the large pipes quickly on each cycle.
And the rad vents will have to only vent themselves.
Going from coal to on/off burners changed the paradigm of steam heating, it has taken about 50-70 years for most of the industry to recognize this, IMO.1
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
