Taco High Point Air Vents
Docfletcher
Member Posts: 490
in Gas Heating
I'd like to know if the 416-2 and 400-4 function identical to each other in a hot water boiler application? I've been told the 416-2 is designed for higher pressure applications. I'd like to use the 416-2 on a air scoop. Thanks
Yes I have seen the difference in the Max venting pressure 50PSI for 400-4 and 115 for 416-2. But will either work just as well for residential boilers? Thanks0
Thank You.0
