Hydronic Baseboard heaters only getting hot on one side of my home
2»
  • rick in Alaska
    rick in Alaska Member Posts: 1,500
    Since it is a monoflow system, I would try bleeding at the baseboards themselves. Sometimes depending on how much debris is in them, they might not want to purge with just a common return point at the boiler. Hopefully there is a shutoff valve on the baseboard just past the bleed fitting which will make it easier. And hopefully there is a bleeder fitting on it.
    Rick
  • JUGHNE
    JUGHNE Member Posts: 11,487
    You think this is a monoflow system?
    Not just straight BB?
    I did see a couple of tees that might of had just a faint trace of a ring on one side, but not that clear.
  • rick in Alaska
    Now that I look at eh picture a little closer, maybe not. That first tee looked like it was, but now I am thinking maybe it's just the way the light is hitting it.
    It does however look like a balancing valve on the pipe on the right just as it goes in the sheetrock.
    Rick
  • neilc
    neilc Member Posts: 3,040
    congrats
    known to beat dead horses
