High temp sealant/retort cement recommendations?
delcrossv
delcrossv Member Posts: 2,203
Any product recommendations for high temp sealant/ retort cement for resealing a dry firebox to a cast iron heat exchanger and resealing the exchanger to the draft hood?
Something that can be applied outside the joints as the boiler won't be coming apart to put the sealant under the flanges.
