T stat for radiant floor
Gta
Member Posts: 151
Hi , what is a great t stay for radiant floor heat ? I have rehau digital ones and I hate them , they turn on/off with a .1 c temp change. I need something simple and reliable that works thx Sean
This is the one I want to replace,0
Tekmar makes some nice/simple ones. IDK what you mean by turn on and off. Maybe something is not set right, or a wire is loose. Not enough info.
I installed Tekmar 519 with floor sensor and it works perfect.
Thank you,
Hiren Patel0
